I have just downloaded and installed Dynamic AI Personal Edition and installed it on my PC without any initial problems. I connected successfully to my MySQL database running on a remote server.
However, although most tables can be viewed successfully, others result in the error message "ODBC driver does not support the requested properties." I'm only trying to view the data in the table, not even trying to manipulate the data. As luck would have it, it's the tables that will not view that are needed to create the reports that I want to generate.
Can anybody suggest what the problem might be?
Many thanks.
