Error connecting to SQL Server
Support documents related to Microsoft SQL Server, Microsoft SQL Server Express, Microsoft Access and Microsoft Excel Databases
Postby Pepe » Thu Jul 22, 2010 11:04 am
We have a new client with A Dynamic AI Named User Server license. The setup is as follows:
a) Dynamic AI running on a Windows 2003 Server 64 bits
b) Microsft SL Server 2005 running on a Windows 2003 Server 64 bits
Afetr setting up IIS to be able to run in 32 bits mode Dynamic is working OK. Logged in as Administrator and changed passwords.
We are unable to make a connection to the SLQ Server from Dynamic.
We have trie with the server name and IP address of the machine. No special ports and only one instance of SQL running on that server. We have tried with different SQL users: SA and one created specifically to test with all the permissions. We keep getting "Error on initializing session for the user" (or something similar translated from Spanish).
With a Personal Edition on a PC on the network they were able to connect to the Database.
Any hints of what might be wrong?
TIA
Pepe
Re: Error connecting to SQL Server
Postby Carsten Sørensen » Fri Jul 23, 2010 8:19 pm
Hi Pepe,
Did you get a solution?
Postby Pepe » Mon Jul 26, 2010 11:34 am
Problem just solved
The customer had some problems with MS-SQL restrictions, password expiration and user locking that he managed to solve this morning.
Pepe
Return to Microsoft SQL Server / Express / Access / Excel
