Connecting to Microsoft Access 2007 is different than previous Access versions (please see separate topic for MS Access 97-2003).
Use the database connection screen in Dynamic AI and select Access Database 2007 from the Type list.
Use browse to find and specify the database file OR type the full path to the file.
Browse will only be available when you are using Dynamic AI on the same PC as where you have installed Dynamic AI. If you setup connection on a Dynamic AI Server or Enterprise edition - be aware that you should specify the path as seen from the server.
Be aware that Access is a file-based database and that the windows user used by the Dynamic AI installation has sufficient (read/write) access rights to the file.
If your database is protected with a database password - please specify the password:
Click SAVE to save the connection. Now you should see the database in the database Explore and be able to browse and use Tables and Views of the database.
ODBC/OLEDB driver
In most cases the needed database drivers are already installed. However if you experience problems with the connection then you should check whether the ODBC/OLEDB driver for Access is installed. This can be checked in the Control Panel -> Administrative Tools -> ODBC Driver.
Under the tab System DSN press ‘Add’. Check is if the MS Access ODBC driver is installed.
If there is no ODBC driver installed you can download the MDAC client from:
http://www.microsoft.com/downloads/deta ... laylang=en
This driver contains core Data Access components such as Microsoft SQL Server, OLE DB provider and ODBC driver.
Sample data
The DEMO optionally installed with Dynamic AI includes a sample Microsoft Access DEMO database (V6_Demo.mdb - 97-2003 format) connected to Dynamic AI and used for reports etc.
Microsoft, Windows and Access are registered trademarks of Microsoft Corporation. All other products may be trademarks or registered trademarks of their respective companies.
