Cannot See my Tables
Postby Squarehoop1 » Wed Oct 15, 2008 12:01 am
I built a connection to my SQL Server database. The Test Connection comes back successful. However, when I click on Tables under my connection it comes back and says No Data Found.
Any thoughts on how to get the Dynamic AI to see my tables?
Squarehoop1
Postby Carsten Sørensen » Wed Oct 15, 2008 12:13 am
I assume that you are using the direct connection (not using ODBC) from Dynamic AI? Can you try with a user that has got more rights (like the sa). Try without an OWNER/SCHEMA if you specified that.
Your MS SQL Server should allow database authentication (setting at DB level).
Cool Beans
Postby Squarehoop1 » Wed Oct 15, 2008 12:35 pm
I took out the entry I had for Owner/Catalog and it worked. I had been using an adminstrator login as you had suggested. But, removing the owner seems to have done the trick.
Thanks for the help.
Squarehoop1
