Mikkel,
Thanks so much for your reply. Using it I have had managed to produce the graph I described ... but there are still problems ....
As I mentioned, the data I have is quite raw, actually machine runspeed and timestamp recorded at 1 minute intervals, so there is no real summing, averaging or similar to do on the data, which appears necessary for the graphing facility. Intention is just to provide a zero referenced speed runchart over nominated periods. Anyway, I thought this wouldn't be a problem, as I simply nominated to apply MAX to the minute interval runspeed figures.
I found this generally works ok .... except when the runspeed is 0.0, that is, when the machine is stopped. In this situation, no value (blank) is shown in the associated report, and the graph will not generate. So in short, I can produce a speed runchart for a given time period only if the machine runs continuously.
Unfortunately this is not generally the case for our machines, hence the value of a runchart. Must say that the appearance of the blank maximum values in the report has taken me rather by surprise. A simple report looking at the raw data shows data values of 0.0 ok. Appears the maximum value of 0.0 is not defined?
Some other issues I've encountered, atleast with features available with the personal edition:
- Although wanting to use minute-by-minute data, labelling on the x-axis becomes very crowded and generally unreadable. I can't see a way of indicating that just 'enough' labels are required, regardless of the number of data points involved.
- If a machine does run continuously for an extended period, the graph auto-scales the y axis and only shows the runspeed variation. This might be ok, but not what is generally wanted for a speed runchart. I can't see a way of specifying a fixed minimum value (say 0) for the y axis.
Once again, thanks so much for your reply, as it has helped me understand the graphing mechanism. Unfortunately it seems to me that the particularly basic requirement I have may not be ideally suited to DAI. Please, if you have any other advice it will be greatly appreciated.
Regards and thanks,
PS
I would attach some relevant images but can't quite understand how to achieve this in the editor.
