Hello guys.
I'm trying to find on help or on demo example how to make the List Box on dictionary to work, but I didn't find it anywhere.
I have a particular field that a comobox wolud be perfect for it every time it appears, so I would like to put this information on dictionary. This fiels has only 4 single options.
But the AI default behavior would search my entire database table to build the list for just only 4 itens. I don't want this behavior.
The problem is that I don't know how to update these fields on dictionary and on demo there is not an example to do some thing like this.
I tryed this but no success:
On dictionary maintenace page, select the aproprieate field to update, then:
"List Box Value" = "CJ;J1;J2;EV"
and
"List Box Display" = "Conferência Internacional;Conf de Jovens - 1º Período; Conf de Jovens - 2º Período; Evento Genérico"
I don't know the correct way to edit these fields. What is the itens separator character?
Like this, when creating a report based on this table, when I try to create a filter for this field on "List Options" tab, I changed the Search Type to "Select" and then the page to edit the filter options came whit a field "Use Dictionary" pre-selected and also a field with the content:
"Click to retrieve available lists". When I click on this field, the AI closes every thing and makes a log-off. and the page that appears Is the login page!
Please, send me informations to make this work. And would be nyce to have some example of this on demo too!
Samuel Pizarro
Estância Árvore da Vida
