AI 6, accessing DB2 Express C-9.1 on Windows 2003 Server.
I get this error on some tables from my DB when I click on Table Name inside "Explore Database".
- Code: Select all
Dynamic AI can't open the list Operac:
While executing SQL against the IBM DB2 OLEDB (192.168.1.4) database, a problem arose.
The issue reported from the database is:
[DB2/NT] SQL0206N "DAI_.CODOPERAC" não é válido no contexto em que foi utilizado. SQLSTATE=42703
You can click here to open the Report in Design for investigation and for editing.
DAI 0002000-24 SELECT DAI_.CodOperac, DAI_.Descricao, DAI_.RECNUM, DAI_.Tipo FROM DB2ADMIN.OPERAC DAI_
This is happening with 3 or 4 tables. But the table is accessible by another app normaly.
I noted that tables that have fields name with Upper and Lower case, this problemas happens. And tables that have just UpperCase field names, AI can build the list.
What is Happening?
