Date & Time Display
Date & Time Display
Postby TomBoynton » Thu Jan 10, 2013 4:44 pm
Is there a way to display the System "date and time" on a report?
TomBoynton
Re: Date & Time Display
Postby Bob Cergol » Thu Jan 10, 2013 5:07 pm
Hello Tom,
Just by changing the report type from "list" to "report" will cause audit information to appear on the report according to the style sheet in use. This will show the date time stamp when the report was generated, the user credential that ran the report, the full menu path of the report and report version. The default format of this information using the default style sheet is pretty faint (light grey) but readable. You can control the formatting by changing style sheets and/or modifying the colors in the sheet and saving as a new custom one.
Also "report" type reports implement other settings defined in the style sheet -- such as adding a logo, rules, etc.
Finally, since output is HTML, you can also include logos and other content using the report hearder/footer entries found on the about tab in report design.
