Password Reset
Password Reset
Postby cjbates » Wed Dec 12, 2012 2:55 pm
Is there someplace in the User setup table or system setup where I can control how/if users have to change their passwords? I need to turn off the requirement that users change their passwords. Thanks.
Re: Password Reset
Postby admin » Wed Dec 12, 2012 3:51 pm
Hi Cynthia,
In Administration, under System / System
The properties in the red box controls user password policy
NOTE: Do not set the "Force SSL on" option here unless you have SSL enabled on the web server - it will immediately prevent access to the system :(
Re: Password Reset
Postby Bob Cergol » Wed Dec 12, 2012 3:58 pm
Hi Cynthia,
Look at: Administration / System / System / Security tab.
There you will find options for controlling password policies.
Please don't enter blank values -- enter 0 instead as appropriate.
For password duration enter a reasonable value, i.e. don't enter 999999999999999999999 days. In some older builds that caused a problem.
You can also force user to change their password or set a date range for access on the user profile account tab page. I think you need to enter those dates in yyyy-mm-dd format.
