The 3 default languages
Postby jldum » Wed Feb 13, 2008 1:55 pm
in the previous versions of DAI, one could via a system page access the setting for the 3 base languages
I do not find this back right away in the new navigation ?
thanks for your hint.
Jean-Luc Dumont / Belgium
Dictionary languages
Postby Carsten Sørensen » Fri Feb 15, 2008 6:05 pm
Hi Jean-Luc,
Use the last tab of the System option (in the Administration menu) to set the 3 dictionary languages.
The base languages will then be available from Dictionary maintenance in Dynamic AI Server editions.
You'll find Dictionary maintenance in the Administration menu. A new feature in Dynamic AI version 6 is that you also have access to create and maintain the base languages directly on the table/View objects from Database Explore. If you click on the drop-down triangle next to e.g. a table in explore - you'll see the options to create / maintain dictionary entries for the table. If a dictionary has already been created the drop-down triangle is green.
In Internet Explorer you'll be able to get to the drop-down menu with Right-click as well.
Dictionary maintenance now also offers SQL Global Columns, specific Roles maintenance etc.
