Report vs e-Mail/Schedule
Postby WStansbury » Fri Oct 12, 2012 4:50 pm
There are times when I create a report and then e-mail/schedule the report, the report looks completely different.
See Attachment for an example.
dai_email.docx
(307.31 KiB) Downloaded 2442 times
WStansbury
Re: Report vs e-Mail/Schedule
Postby Carsten Sørensen » Fri Oct 12, 2012 4:57 pm
We'll check - but it might be a case of the "current" between date filter not being applied correctly.
Can you try with a specific date instead of the between .. syntax?
Thanks for reporting this!
Postby WStansbury » Fri Oct 12, 2012 9:51 pm
That was the problem. Bad Filter. Thanks as always for your fast response.
WStansbury
