 by Bob Cergol » Mon Aug 27, 2012 1:37 pm
			Hi Wayne,
I thought the issue with the dashboard was the filters were not applying to all of the reports. Since Dan mentioned they were built on different joins I said to set the filter scope to "global". I hadn't heard back so emailed him asking if it fixed the problem. He said "no" and that he suggested you post the issue here.
Were you previoulsy also getting an error message -- or is this new since you changed the filter setting?
If you'll email me the report numbers for the reports comprising the package I will have a look at them directly on your system.
