Dashboards
Dashboards
Postby robinsonky » Fri Mar 16, 2012 5:57 pm
Any restriction on the types of graphs that can exist in a dashboard?
I'm trying to put 2 HC line graphs into a sales dashboard but get just the header and the colour-key legend, and a '1' top left corner for the first graph, and nothing at all for the second.
edit: I also get the top-left drop-down menu, with 'open alone'. 'open alone' works.....
robinsonky
Re: Dashboards
Postby Bob Cergol » Fri Mar 16, 2012 8:30 pm
What version / build of Dynamic AI are you running.
There are working examples of dashboards with high charts in them.
The only caveat using them is they won't email, i.e. an email of the report won't show a graph. (Email readers tend not to execute javascript in an email so no javascript is transmitted! :wink: ) You can email the static TCharts.
Re: Dashboards
Postby robinsonky » Fri Mar 16, 2012 9:42 pm
the 'timeline' HC works fine. Just not the HC line.
.. and DAI vers: 6.4.59
[removed question on activex answered in other post]
robinsonky
