Connecting to the database was successful! Error Msg 3265
Postby fnowo » Fri Nov 04, 2011 8:09 am
Dynamic AI can't open any typ of tables or Views
While connecting to the Oracle database a problem arose. the tables and views will be listed, on access on a Table or View the following error will be reported:
3265 : Ein Objekt, das dem angeforderten Namen oder dem Ordinalverweis entspricht, kann nicht gefunden werden.
Please check that the Database server is running and that Dynamic AI have sufficient access rights to access it.
we are using the folowing components
-Dynamic AI 6 Server v6.4.30
-Windows Server 2008 WEB Edition (x64)
-Oracle Client 11g Release 2 (11.2.0.2) for Microsoft Windows (32-Bit)
-Oracle Server 11g Release 2 (11.2.0.2)
The access on the tables over sqpplus works fine, so we don´t have access problems.
What can we do?
Fabian
fnowo
Re: Connecting to the database was successful! Error Msg 326
Postby admin » Fri Nov 04, 2011 10:31 am
Hi Fabian,
I don't have a good answer for this yet, I will have to try myself.
In the meantime, can you:
-tell me which connection type you use in the connection definition? There are two - can you try the other one
-take a sql statement that works in sqlplus and create a dynamic ai view with that statement. See if you can save and browse this.
There is to my knowledge not a general problem with connecting Dynamic AI 6.4 and Oracle 11, but I will make some tests.
Postby fnowo » Fri Nov 04, 2011 11:26 am
connection type "Oracle Database"
Test Connection: Connecting to the database was successful!
Tables: will be listed
Views: will be listed
Dynamic SQL View: Error Msg 3265 : Ein Objekt, das dem angeforderten Namen oder dem Ordinalverweis entspricht, kann nicht gefunden werden.
connection type "Oracle OraOLEDB"
Tables: No data found
Views: No data found
Dynamic SQL View: Displaying records
fnowo
Postby Bob Cergol » Fri Nov 04, 2011 1:34 pm
PMJI....
Can it be a rights issue for whatever credential is being used in the connection?
Can you view table data on the same PC using an Oracle utility, or any interface other than Dynamic AI with the same user credentials?
Postby fnowo » Fri Nov 04, 2011 1:56 pm
hi Bob Cergol,
i´m tested on the same computer the connection over sqlplus from oracle client 11 and dynamic ai.
The connection works and the select statement will be resolved.
we are used the same oracle account for all connections to the database.
best regards fn
fnowo
Postby Eddy Kleinjan » Fri Nov 04, 2011 2:13 pm
Hi Fabian,
If you have time right now, we can do an online session so I look over your shoulder to see what is going on. Please send me an email at eddy.kleinjan@dataaccess.eu with the details on where I can contact you so we can arrange the details.
Eddy Kleinjan
Data Access Europe
Eddy Kleinjan
Postby fnowo » Fri Nov 04, 2011 3:28 pm
i created a new connection over ODBC, over that connection (with the same oracle account) the tables will be displayed.
fnowo
Postby fnowo » Fri Nov 04, 2011 3:31 pm
i´m updated the Dynamic AI Server Edtion to v6.4.47 without effect
fnowo
Postby fnowo » Mon Nov 07, 2011 7:32 am
with the odbc connection the tables can be listet, but every type of reports send also an error msg.
The issue reported from the database is:
Der ODBC-Treiber unterstützt die angeforderten Eigenschaften nicht.
(the odbc-driver dosn´t support the properties)
fnowo
Postby Eddy Kleinjan » Mon Nov 07, 2011 9:24 am
I went into an remote session with Fabian to see what could cause the problem that they had reported. It turned out that the field 'catalog' had a value. When this catalog field has a value, then that value will be used as a filter when showing the available data sources. Once we removed the value from the 'catalog' field, all data sources became available in Dynamic AI.
Eddy Kleinjan
Eddy Kleinjan
Postby fnowo » Mon Nov 07, 2011 9:43 am
now it works fine.
thx for the fast help.
best regards fabian
fnowo
