unfortunatly, the solution you mention in my other post ("multiple pie chart on same report") does not work with the HC Pie model, as this model cannot be edited.
And if I do not use the HC Pie Model, I cannot decide which colors need to be used
The report I try to create is to see betwween 2 separates pie the evolution of the risk priorisation from a year to another, and I need also to have a specific color for each level of priorisation.
The sql statement send back the following datas
- Code: Select all
RIS_NAME PRIORISATION YEAR N-1 PRIORISATION YEAR N
R1 1 1
R2 2 1
R3 1 2
R4 3 1
R5 3 3
R6 3 3
R7 2 1
1st pie : Priorisation 1 : 2 risks
Priorisation 2 : 2 risks
Priorisation 3 : 3 risks
2nd pie : Priorisation 1 : 4 risks
Priorisation 2 : 1 risks
Priorisation 3 : 2 risks
For the moment, If I do understand correctly, if i do not use HC Pie, I can have those 2 pies on the same report, but without the specific color.
if I use HC Pie, I have the specific color, but I cannot have 2 pies on the same report, and if i use a dashbord the specific colors are not used.
Is there any other solution I can try (by the way, I work with the 6.4.31 version)?
Jérôme
