I want to add a condition linked to an alias and I don't succeed.
If the field is a text field, do I need to put apostrophes around the alias ( >'@alias1' )
and if it's an integer ?
This point is solved. I have found that I need to put the apostrophes in the value of the alias in the user management.
In the SQL condition "J2.zipcode > @alias1 and J2.zipcode < @alias2" doesn't work. I receive as error message
Conversion failed when converting the varchar value 261-31 to data type int.
The Zipcode field is a text field.
Jacques
