SQL Problem
SQL Problem
Postby jollt » Fri Aug 05, 2011 1:18 pm
when I call a report from my application, I get this error :
When I execute the same report directly on DAI, I do not have any error : the report works.
I checked the trace (Administration/Activities/Log Alerts/General alerts) and can see my error :
Is the any trace log where I can see the last generate sql sentence?
regards, Jérôme
jollt
Re: SQL Problem
Postby admin » Fri Aug 05, 2011 1:30 pm
Hi Jerome,
I'm not sure that any sql had been executed at this point - can you share the call you make from the application?
Otherwise you can monitor the incoming traffic to your database server.
Re: SQL Problem
Postby jollt » Fri Aug 05, 2011 1:50 pm
I use an API I develop to open the reports in DAI which works correctly.
The report I try to access was working this morning, I just change my sql request :
This morning I use :
select GlobRisReport.* from table (GLOB_RIS_REPORT(43, 'FRANCAIS', 683)) GlobRisReport
Then I add a parameter to my stock procedure : @userid
select GlobRisReport.* from table (GLOB_RIS_REPORT(43, 'FRANCAIS', 683,'@userid')) GlobRisReport
If I execute this request on DAI (database menu), it works
If I execute the report based on this request on DAI, it works
If I call the report from my application with this request, I have the sql error
I use this syntax with orther reports and othe stock procedure and it works
Jérôme
jollt
Re: SQL Problem
Postby admin » Fri Aug 05, 2011 2:03 pm
I was after the "final" url that the api generates - if you can intercept that, it would be interesting. You are welcome to send as a private message if you want.
Re: SQL Problem
Postby jollt » Mon Aug 08, 2011 3:16 pm
I might have a problem with developoment environment (where it's not working) as it's works perfectly in my production environment.
Jérôme
jollt
