List of Reports
List of Reports
Postby ax_dynamic » Tue Jun 21, 2011 9:33 am
is there any way create a report that lists all the reports in my dynamic system containing for example all the information on the "General"-page like Categorie, Group, Name, Connention, User-Group and so on ?
Axel
ax_dynamic
Re: List of Reports
Postby admin » Tue Jun 21, 2011 10:18 am
Hi Axel,
I assume you are working with the server version. If you use personal or enterprise edition, please write back.
You will need to create a connection to the Dynamic AI repository. I will send you a private message with the details.
Make sure you do not make the connection writable!
Then create a report on the DNMCRIGHTS table.
You can easily find the requested information in here.
