adding +columns from different database
Postby dfischer » Thu Dec 02, 2010 4:46 pm
is it possible to compare data from different databases, by adding extra columns into a report, that come from another database? We're working with oracle databases, mainly.
What I tried is joining two databases, that are the same in structure, via a dynamic relation. That way I can link data in a form, by setting them next to each other.
What I would like to achieve is a comparison of all rows, and just showing the ones, that are not the same on both databases. Is there a way you can suggest?
Thanks in advance.
Kind regards,
Daniela Fischer
dfischer
Re: adding +columns from different database
Postby Carsten Sørensen » Thu Dec 02, 2010 4:54 pm
Hi Daniela,
In the more recent releases of Dynamic AI there is a Package compare feature.
1. Create 2 detail listing reports with the columns you want to compare
2. mark the 2 reports using the checkboxes next to the reportnames in the menu and create a new package
3. Enter Design (using the tools menu)
4. Check "Compare reports" (optionally decide whether you want to see the difference as HTML, CSV or XML
you'll get:
Postby dfischer » Thu Dec 02, 2010 5:27 pm
thanks a lot for your quick reply.
What you described sounds like the perfect solution for me!
We use DAI release 6.4.15. What release supplies the compare package and where would I find it?
Daniela
dfischer
Postby Carsten Sørensen » Fri Dec 03, 2010 8:31 am
Hi Daniela,
You'll find it as an option on the "Package", "General" Tab:
