Creating graphs will give you the standard properties from a style sheet. Dynamic AI is able to create custom made style sheets 'Free List Styles' which allows you to change the size of your graph.
Steps:
Go to Administration -> Styles.
- Select i.e.: 'Std 01' and open it.
- Adjust this style sheet bij adding: #TChar1 {width:800;height:800;}
- (Change the width and height to your needs).
- Save this style sheet with name i.e. : 'Std 01 custom made'.
- Now go into design mode of your graph.
- Select the 'List' tab.
- In the dropdown 'Style' select your 'Std 01 custom made' style sheet.
- Save your design.
