In my application of DAI, one primary use of graphs is for the presentation of machine run time data. Generally this data is collected from machines at 1 minute intervals. One limitation I've found from early on is the limitation of 999 bars or points within a graph. This is a limitation when considering displays such as run time as, for example, this allows for less than a single days representation of 1440 1 minute values.
As an example, in a work-around for daily run charts, I've resorted to using 'mod' functions to display only every 2nd value, but this approach is not really ideal. I realise this is probably not a typical application of DAI graphing features, but trying to overcome the graph content limit is one area which I think warrants some consideration.
So, I'm wondering if there is any means of increasing the default limitation of 999 data points for a graph, realising, of course, that setting of sensible limits still needs to be maintained.
