Dynamic SQL View not saving default @PARn@ value
Postby shearerg » Wed Sep 08, 2010 5:12 am
I'm trying to use a parameterised Dynamic SQL View in Personal Edition which I have working already in the Server edition. The definition tests OK in design mode, but when I save the definition the @PAR1@ entry and default value (@DATE:NOW()) is not saved. This means that when the View is browsed or specified for a report a database error results.
Am I doing something wrong? It doesn't seem likely to me that this could be a real bug, as it would have already been noticed by other users. Any advice will be appreciated.
Re: Dynamic SQL View not saving default @PARn@ value
Postby Carsten Sørensen » Wed Sep 08, 2010 6:22 am
Dictionary functionality is not part of the personal edition. @PAR's are stored and maintained through the dictionary which is a Server edition function only.
It is a bug that you can define them.
Postby shearerg » Wed Sep 08, 2010 6:53 am
Understood. Must admit the process for defining @PAR1@ did seem a little odd, as the means was not presented within the initial definition screen. Trust me to find a way :wink:
