handling larger table
Postby jldum » Thu May 27, 2010 2:05 pm
trying to slice and dice on a table of 145 Mb, 700 000 rows, 21 columns
2 problems
1. when the drill to form is ENabled , only a limited set of rows is returned
2. when the drill to form is DISabled , totals is OK, but I do not see all aggregated rows
see .doc attached
Where can I find the doc to master this ?
thanks
regards
DAI_test01.doc
(203 KiB) Downloaded 842 times
Re: handling larger table
Postby Carsten Sørensen » Thu May 27, 2010 7:45 pm
Hi JLD,
700k rows and 21 columns shouldn't be a problem at all - we have tons of those also bigger all over.
Drill to Form should have nothing to do with this.
Can you "prove" that your data includes data in other than the 3 months shown? You'r list shows n = 699,142 as you have stated so I can't really see where the problem is?
You have 100.000+ records underneath each group therefore the maximum number of records per page is kicking in (as we assume that you don't really want 100.000 records of details.).
I think the problem is in the Year/Month -can you try grouping in 2 individual group columns instead of the concatenated version?
Postby jldum » Mon May 31, 2010 4:18 pm
right,
I am using the 'group caption' feature and was expecting the report to show me a
list of 36 rows with a Jaar-maand total at each level
Actually what I got was any concatenated caption jaar+maand with the jaar total on the row.
Probably have to make a calculated field to be used in the SQL ...
regards
Postby admin » Mon May 31, 2010 4:35 pm
Hi JL,
The group caption feature you're referring to, is meant to merge 2 fields on the grouping level. It expects that there is a 1-1 relationship between the fields.
It is usually used when a table has column pairs such as Product ID / Product Name - Account number / Account Name - fields where all records with a particular value in one of the pairs fields, also has the very same value in the other pair fields. This way, we can group on productID and productName and show them on the same group level.
If you have a date field in your data, you can group on that, and then pick a date format such as YYYY-MM that would render a date like 2010-05-30 as "2010-05", and give you 36 distinct values (=groups) for a 3 year period.
