Using Roles (Security set up)
Postby jldum » Tue May 11, 2010 12:29 pm
I found Roles info on
A. Users profile
B. dictionnary (table / column level)
How would it work ?
setting value in Dictionnary , is it a toggle (0 or 1) ?
the 2 points (A, B) above are the only one to use ?
What about the following case ?
Column1 A=0, B=0 (in Dictionnary)
Column2 A=0, B=1 (in Dictionnary)
User 1 A flagged , all other not (in profile)
User 2 A & B flagged , all other not (in profile)
Should then user 1 not see column 2 in reports ?
Re: Using Roles (Security set up)
Postby Carsten Sørensen » Tue May 11, 2010 12:32 pm
Hi JL D,
I believe you can find some descriptions about Roles functionality in the documentation.
http://support.dynamicai.com/help/Dicti ... enance.htm
include some information on roles.
