v.6.4.12 - how to select value on graph
Postby jldum » Wed Apr 28, 2010 4:41 pm
I have a base table 'invoices' with columns year, month, fact.date,BusinessUnit, XXXX, ProdNr, ..., Qty, weight, amount
I create one report as
group on BusinessUnit, XXX,ProdNr
total on Qty, weight, amount
column hdrs are thus the value names
I add a graph and would like to only show one (1) of the (3) values
do I have to create another report with one value and show the graph in a page ?
thanks
regards
Re: v.6.4.12 - how to select value on graph
Postby Carsten Sørensen » Wed Apr 28, 2010 10:08 pm
Hi JLD,
Adding another report with only the specific totals is an option you can use. If you put the report and the new graph in a "package" you can have them follow the same filters etc.
Another option (available in the Server and Enterprise editions) is to create a specific template to only show the individual total.
