Dynamic AI and SMTP Service questions
Postby Bob Cergol » Thu Jan 21, 2010 8:07 pm
The web server on which Dynamic AI resides does not currently have an SMTP service installed. The DAI docs state you must have such a service running on the IIS web server. I might not be in a position to install that service on this server, but an SMTP service is already available on our network. I call this service from within my VDF applications using BLAT. I'm wondering if I can configure DAI somehow to use that same service and avoid dealing with changes in our network infrastructure over which I have no control.
Re: Dynamic AI and SMTP Service questions
Postby admin » Thu Jan 21, 2010 9:12 pm
If your SMTP server does not require authentication, it's fairly easy - just enter the name of the smtp server on the system configuration page shown below
If it does require authentication, you need to specify additional parameters in the system parameters section:
We support two different authentication schemes: Basic and NTLM, the difference being whether the password is encrypted or not.
If you use Basic (unencrypted) authentication, the following 2 parameters need to be set:
SMTPUID : User ID
and
SMTPPSW : password
For NTLM authentication, also specify a parameter SMTPAuth with the value NTLM:
Postby Bob Cergol » Fri Jan 22, 2010 3:18 pm
Thanks Bo!
This was "easy as pie".
I tried it and it just works.
Now I can spoon-feed the hungry ... :wink:
