Can't open the list error message
Postby Bob Cergol » Fri Jan 08, 2010 8:12 pm
I've gotten this several times the last several days, sporadically, but mostly ignored it and I didn't note the pattern leading up to it.
Just now I had added a date(YYYY) at the top of my grouping to test. I ran the report for all years -- and it took a while but it displayed data. Then I changed the year multi-select from "*" to 2010 & 2009 and clicked "go" and got the error.
I played with it some more and it runs if I select only 2010 or all. If I select 2008 or 2009 I get the error.
Re: Can't open the list error message
Postby Carsten Sørensen » Fri Jan 08, 2010 8:17 pm
The error indicates that something is going wrong during alias replacement.
Can you send me the report doc offline so I can take a look at it. + which alias values you have set for the current user.
