I'm exploring the user / groups setup. I would expect to define rights at the group level and then override them at the user level. Though I see a nearly equivalent way of doing that is to copy a user profiles to a new user, so perhaps the point it moot. On the other hand if one wants to change a right for all members in a group, then you have to edit each individual user.
Am I correct in interpreting that an alias parameter is intended to be defined at the system level and then the specific value for that matching numbered alias is set at the user level.
Example: System Alias 1 = Account ID
User Spen D. Slotsofmoney from a big account has his alias1 value set to that accounts ID as it would occur in orders, invoices, etc. for that account.
In other words you shouldn't expect to use Alias1 for different purposes as the definition of its meaning is global ? (Now I'm thinking no, any given report would simply use that alias value -- and it may or may not make sense depending on the combination of report and user.)
