Hi Mr.Anderson and Carsten,
I really appreciate your prompt reply. I am really impressed your quick feedbacks. On doing further investigation I found the differences between two VMs that I have been using to do install -
VM-1 -- Installation failed,but the product is working.
The product is working. But the Program Files\Dynamic AI folder does not DLCL directory and many othe scripts and files that were listed in the documentation.
See the output of 'dir' command ran in the Installation Location --
E:\Program Files\Dynamic AI>dir
Volume in drive E is Data
Volume Serial Number is 04D2-6C3A
Directory of E:\Program Files\Dynamic AI
11/26/2009 06:05 AM <DIR> .
11/26/2009 06:05 AM <DIR> ..
11/26/2009 02:58 PM <DIR> COM
11/26/2009 06:05 AM <DIR> DAT
0 File(s) 0 bytes
4 Dir(s) 1,101,748,224 bytes free
E:\Program Files\Dynamic AI>cd dat
E:Program Files\Dynamic AI\DAT>dir
Directory of E:\Program Files\Dynamic AI\DAT
11/22/2009 05:15 AM 186 activation.ini
12/11/2007 11:02 AM 200,704 BAK1_6_3_23_LCLDNMC.dai
12/11/2007 11:02 AM 200,704 BAK2_6_3_23_LCLDNMC.dai
06/24/2009 05:04 PM 1,474,560 BAK_6_3_23_DEMO.dai
12/11/2007 11:02 AM 200,704 BAK_6_3_23_LCLDNMC.dai
5 File(s) 2,076,858 bytes
2 Dir(s) 1,101,748,224 bytes free
E:\Program Files\Dynamic AI\DAT>cd ../com
E:\Program Files\Dynamic AI\COM>dir
Directory of E:\Program Files\Dynamic AI\COM
11/26/2009 02:58 PM <DIR> .
11/26/2009 02:58 PM <DIR> ..
0 File(s) 0 bytes
VM-2 -- Installation failed and product is not working.
I get 'Cannot connect' page when I click on the 'Open Dynamic AI' shortcut.
But this installation has many files listed in all the directories including 'registering' & 'unregistering' scripts.
This is matching with the documentation.
I am still confused to understand about what is happening.
I would be very happy to open a WEBEX to troubleshoot the problem. You can send me an email, when you are ready to do so. My email addres is
bgunda@ostusa.com Thanks,
Bhaskar
