DynamicAI Login Error
Postby areatecnica » Thu Jul 09, 2009 12:10 pm
I recently downloaded Dynamic AI rel. 6 for free and installed on my WIN Vista Home Premium with IIS7.
When I start I receive this error "During DAIlogin 0000550 the Dynamic AI Server raised an error!".
Another question, why during the setup the wizard non let me choice between IIS or other WEB SERVER like the embedded ?
DinamicAI seems to be fine and I'll be very happy If I can use it, can you help me ?
Thanks a lot
Enrico
areatecnica
Postby admin » Thu Jul 09, 2009 12:22 pm
Hi Enrico,
To answer your second question first.
Dynamic AI has been developed for IIS. The Quickweb option works very well, but if IIS is already installed on a computer, we don't feel there is a need to install additional software that performs the exact same function.
I can't tell what causes the problem you have. I'd be happy to take a look, if you send me the files
    activation.ini
    lcldnmc.dai
found in the folder c:\program files\dynamic ai\dat\
you can send it to boa@cintac.com
First you may want to check the version of Dynamic AI you have. The latest version is 6.3.11. It can be found on
http://www.dynamicai.com/download.htm
Requested Files Sended
Postby areatecnica » Thu Jul 09, 2009 1:11 pm
thanks for your reply, I just sent the requested files.
Waiting for your reply, have a nice day.
Enrico
areatecnica
