How Drill Down on List Like report
Postby jldum » Fri May 08, 2009 11:40 am
I am trying (I think again after being away for months) the following
I have 3 tables related by one-t-many relations
I joined the tables in a DynaView (OK) retaining the columns I want to present.
I want to show 5 or 6 columns for table 1 (higher parent) , each hp column being in one-t-one relation with each other as a list , then
selecting a row at that level,
drill down to the next level (mid parent) each mp column being in one-t-one relation with each other as and show this info as a list ,
then drill down again ....
In a single (collection) report I can not get this to work
caption column seems to be limited to 2 columns,
even trying a 'technical' aggregation does not seem to help....
What would be the way to go here (best practice ?)
regards
Postby admin » Mon May 11, 2009 2:47 pm
Hi JL D,
If I understand you correctly, you can get the result that you want by checking an option on the list:
My steps were:
Create a 3 table join:
Create a report with grouping levels corresponding to the 3 tables:
Check the Option "Grouped values on each row":
Save and run the list:
If this does not do what you were after, please write again, and provide a sample of your join source.
Postby jldum » Thu May 21, 2009 4:18 pm
thanks for the answer.
I'll put this in practice
regards
