Server and Enterprise Edition Version 6.1
It’s possible to create and maintain chart styles – embedded on the report. This means that administrators can modify the chart (Internet Explorer / Active X) using live report data, and save the chart style directly from the report.
Simply select one of the default system styles (lines, bars, pies, areas, gauges etc.) and modify it by clicking Edit below the graph. Now save it as a new graph template.
To use the graph on the report change the report use Design to switch and save the report with a reference to the newly saved template.
Graph templates can be renamed, copied or deleted in Administration/Styles/Graph Templates
