Multiple select filters and multiple compare
Product News
Moderator: Cintac
Postby Mikkel Jensen » Tue May 20, 2008 9:24 am
Two new search types have been added:
- Compare Multiple
- Select Multiple
These filters can be selected under the list options pages filter section under Search Type.
The new filter types has the advantage of giving easy access to create multiple selects by holding Ctrl while clicking on the filters, giving a unique possibility to create advanced compare list of different selected groups of filters.
When running the report you activate the functionality by clicking “…” next to the filter. Otherwise the filter box will work as a normal select or compare filter.
For an example of this please see the standard Dynamic AI Desktop Demo:
Using Internet Information Server:
http://localhost/dynamic/dnmc.asp?M_=PICK_B166
or
http://localhost/dynamic/dnmc.asp?M_=PICK_B164
Using Quickweb Server:
http://localhost:81/dnmc.asp?M_=PICK_B166
or
http://localhost:81/dnmc.asp?M_=PICK_B164
Return to News
