 by Carsten Sørensen » Mon Oct 15, 2007 7:07 am
			- Access to Adhoc Design from Filters button as well as column headings on reports
- Apply button - now available also from Design
- design version number included in report footer
- Underlying Table/View names now shows up (where they can be detected (Join Builder, certain compatible queries and views (e.g. Access)) in Available fields during Ad-hoc changes and Design
- The Excel connection type (internally treated as MS Access) - now has access to all predefined date and numeric functions etc.
- "a_z/z_a directly on columns" implemented in a different way. Clicking directly on report column headers (on level 0) will now (if access rights to AD-HOC), bring the Ad-Hoc change up for the appropriate element type. I.e. If clicking on Detail column headers - then Ad-hoc opens on the Detail Tab. Clicking on a total column - opens on the Totals tab ... etc. Ensuring that the methodology for changing sorting, grouping etc. is the same across all levels of the development and maintenance process. This should further eliminate the need to decide for a default tab.
- More clear background-color showing active report/table/administration task, until focus is moved to the object itself. Should help identifying which report/db object was executed/browsed more easily.
