We are attempting to design a Homepage that users can access via web that will allow them to select one of multiple Dashboard packages. We really like the dashboard package, because it allows you to apply one set of selection criteria to multiple reports.
However, we have encountered a navigational issue that is a big disappointment for us about your product. While I can design my free form page to include links to my different dashboard packages, as well as insert images and links to other types of documents (all that is great) we cannot seem to navigate back to the page from a dashboard package. There is no "Back" button that will return the user to the homepage and if they use their browswer back buttons, it takes them into the report navigation which has been hidden from the user.
Bob Cergol has indicated that I might be able to utilize toolbars to achieve my desired result, but I still consider this to be a considerable oversight and something that you should address in a future release.
) in the bottom right corner.
