First you need a URL for a report you want to include on a Sharepoint page.
Use the information found
http://support.dynamicai.com/forum/viewtopic.php?t=122
and
http://support.dynamicai.com/forum/viewtopic.php?t=123
as well as the report documentation for the report you would like to publish.
The Report documentation with sample URL for embedding can be found here:
The URL will look something like this:
- Code: Select all
http://dynamicai/aidemo/ai.asp?UID=username&PW=xxxxxxx&DAI_F=1049&SFRAME=Y
Next, edit a SharePoint page, click
and select the Page Viewer Web part.
Copy the URL to the Link field and paste it there.
Enter a title for the content, and modify the size of the content window using the fields available under Appearance.
Click "Apply" and you will see a preview of the Dynamic AI report:
Click "OK" and the Page Viewer property sheet will close:
Now exit edit mode and your Sharepoint page is finished.
Note that the Dynamic AI Report is 100% "live" within SharePoint - users can even make on the fly changes to the report if they have Dynamic AI Permissions for it.
Note
Once you are satisfied with the layout and properties of the Dynamic AI Report in Sharepoint, you can Export the settings to a file that can be shared with other users, or loaded as its own web part type. Here is an example of such a file
- Code: Select all
<?xml version="1.0" encoding="utf-8"?>
<WebPart xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://schemas.microsoft.com/WebPart/v2">
<Title>Dynamic AI Content</Title>
<FrameType>Default</FrameType>
<Description>Dynamic AI</Description>
<IsIncluded>true</IsIncluded>
<ZoneID>FullPage</ZoneID>
<PartOrder>0</PartOrder>
<FrameState>Normal</FrameState>
<Height>800px</Height>
<Width />
<AllowRemove>true</AllowRemove>
<AllowZoneChange>true</AllowZoneChange>
<AllowMinimize>true</AllowMinimize>
<AllowConnect>true</AllowConnect>
<AllowEdit>true</AllowEdit>
<AllowHide>true</AllowHide>
<IsVisible>true</IsVisible>
<DetailLink />
<HelpLink />
<HelpMode>Modeless</HelpMode>
<Dir>Default</Dir>
<PartImageSmall />
<MissingAssembly>Cannot import this Web Part.</MissingAssembly>
<PartImageLarge>/_layouts/images/mscntvwl.gif</PartImageLarge>
<IsIncludedFilter />
<Assembly>Microsoft.SharePoint, Version=12.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c</Assembly>
<TypeName>Microsoft.SharePoint.WebPartPages.PageViewerWebPart</TypeName>
<ContentLink xmlns="http://schemas.microsoft.com/WebPart/v2/PageViewer">http://dynamicai/aidemo/ai.asp?UID=username&PW=xxxxxxx&DAI_F=1049&SFRAME=Y</ContentLink>
<SourceType xmlns="http://schemas.microsoft.com/WebPart/v2/PageViewer">URL</SourceType>
</WebPart>
Microsoft, Sharepoint, Windows and SQL Server are registered trademarks of Microsoft Corporation. All other products may be trademarks or registered trademarks of their respective companies.[/code]
