To connect Dynamic AI to a PostgreSQL database, open the database connection screen in Dynamic AI and select PostgreSQL from the Type list.
Enter the ODBC name/System DSN (or create an ODBC connection - see below).
Depending on the PostgreSQL setup Username and Password might be needed.
![Image](http://support.dynamicai.com/forum/images/sup/PostgreConn.jpg)
Click SAVE to save the connection. Now you should see the database in the database Explore and be able to browse and use Tables and Views of the database
pgAdmin III
The pgAdmin can be installed to manage the PostgreSQL database.
Available from:
http://www.pgadmin.org/
ODBC
Below refers to a Postgres Plus installation available from Enterprise DB from:
http://www.enterprisedb.com/products/po ... ownload.do
To get the connection to work, the ODBC driver for PostgreSQL should be installed. This can be checked in the Control Panel -> Administrative Tools -> ODBC Driver.
Under the tab System DSN press ‘Add’. Check whether the PostgreSQL ODBC driver is installed.
![Image](http://support.dynamicai.com/forum/images/sup/PostgreODBC.jpg)
Follow the next steps:
- Go to the Control Panel
- Go to Administrative Tools
- Go to ODBC data Sources
- Go to the tab System DSN
- Click ‘Add’
- Select the PostgreSQL driver
The next screen will appear:
![Image](http://support.dynamicai.com/forum/images/sup/PostgreDSN.jpg)
- Provide the name for the data source. (this name is used in Dynamic AI)
- Provide a description (optional)
- Provide the database name
- Specify "localhost" or other server name
- Enter the port used by PostgreSQL
- Enter a valid username and Password for the PostgreSQL database
- Test the settings
![Image](http://support.dynamicai.com/forum/images/sup/Postgretest.jpg)
The data source is now installed and can be used in Dynamic AI.
If you have problems with the PostgreSQL database, please ensure that the Postgre Server is running:
![Image](http://support.dynamicai.com/forum/images/sup/PostgreService.jpg)
PostgreSQL is Copyright © 1996-2000 by PostgreSQL Inc. and is distributed under the terms of the Berkeley license.
