Hi Carlos,
I've never used server side conversion of the HTML output to PDF, but the docs say:
The user can export a Report in PDF format. Requires that WebGrabber and ActivePDF Server are installed on the Dynamic AI serverAlso, there is a checkbox on the systems settings general tab page to denote if PDF Webgrabber is installed so maybe that is hard coded or there is an undocumented parameter for use with other products. The docs say:
Use this option to make Dynamic AI aware that PDF export is available. Currently the export requires specific PDF 3rd Party software. Please contact CINTAC A/S for details.http://www.activepdf.com/products/serverproducts/webgrabber/I don't know why other similar products would not work. But let's see what someone from Cintac has to add.
You could of course use any virtual PDF printer to print reports (client side) to PDF such as PDF Creator, etc.
