Alias with more than one value
Postby Jacques » Tue Sep 27, 2011 10:12 am
Is it possible to have an Alias which match more than 1 value ?
I mean, if a user is an administrator and want to see all records of a table where some forcefilter are on it, he has no possibility to do it.
I have tried to let no value on the alias but it doesn't work.
A solution would be a general word meaning that all is possible. If it were possible to put more than one value separated by semi-column, it would be a solution too.
In a dynamic SQL view it's possible to write "where '@alias1' = 'ALL" or '@alias1' = D.[A1]" but not in the forcefilter field.
Jacques
Jacques
Re: Alias with more than one value
Postby Carsten Sørensen » Tue Sep 27, 2011 11:45 am
Should be in the documentation - but
@ALL
as alias value should do the job.
Postby admin » Tue Sep 27, 2011 11:56 am
Hey Jacques,
For even more options check this post on alias bundles.
viewtopic.php?f=3&t=170
