Dynamic AI on Android
Postby hellboy » Thu Apr 22, 2010 7:18 am
Hi Everyone,
I know Dynamic AI works fine through an iPhone, has anyone had any experience using it on an Android phone?
The mobile part of Dynamic AI is just done via the browser isn't it, not an actual iPhone Application?
Cheers,
Matt
hellboy
Re: Dynamic AI on Android
Postby admin » Thu Apr 22, 2010 9:59 pm
Hi Matt,
Dynamic AI is working well on Android - at least on the emulator from the SDK.
We built a lighter navigation for the iPhone - on an android (and windows mobile and others) will display the regular interface at the moment.
If you have the personal edition, there is really no way you can try this, as this single user edition can only run from the computer on which is installed, or from an iPhone.
But we'd be happy to let you try a server edition for a while and see if it works on Android for you.
Postby hellboy » Fri Apr 23, 2010 2:00 am
Thanks Bo, we have a license here I can test on, and I've just grabbed the Android SDK and emulator so I'll see how it goes...
hellboy
Postby hellboy » Fri Apr 23, 2010 2:31 am
Bo Andersen wrote:We built a lighter navigation for the iPhone - on an android (and windows mobile and others) will display the regular interface at the moment.
Just on that, I had a quick peek and you're right, it just shows the standard web interface. Is there anything prohibitive about the iPhone interface preventing it from being used in Android (or any other touch based mobile browser I guess). Or is the iPhone interface a little to tied in with the resolution/features of the iPhone?
hellboy
Postby admin » Fri Apr 23, 2010 9:12 am
When we detect that client is an iPhone, we build the
    login screen
    report navigation menus
    single record display (forms)
using iPhone-like styles.
If you can fake the User agent string in Android to include the string "iPod" or "iPhone", Dynamic AI will build the output as if for iPod/iPhone
( I don't know how to do this though - I did this by altering the aser agent string in the debugger.)
- it actually looks fairly good on the android emulator:
